Leinbach L7300 on JD 4120 ??
   / Leinbach L7300 on JD 4120 ?? #1
jamestaylor72
Ashtabula, Ohio
John Deere 4120
Alright Fellas,, steer my right here!! I'm looking at the Leinbach L7300 Post hole digger for my 2006 JD 4120. I have the 17-24 r4 tires on the rear. I've been told by one seller that the L7300 won't fit my tractor,, then told by another that it will. I then called Leinbach directly, and was told that it will fit . Anyone out there running an L7300 or similar size PHD on the JD 4000 series ??? Also, I've seen somewhere here on TBN a fella had an L7300 on his Kubota, which after research I learned was a smaller tractor than mine, which further confused me. I hate to buy a PHD and have fitment issues. And since I'm getting mixed answers from the "people in the know" that I've talked to so far,, I figured I'd see if anyone on TBN could shed some light for me. Also the guy from Leinbach said if my rear tires were at least 4 ft. tall, I'd for sure be ok. Thanks for the input,, it's much appreciated !!! :D
   / Leinbach L7300 on JD 4120 ?? #2
I have one that I use on my Kubota L3400. Works great after some initial frustration.
   / Leinbach L7300 on JD 4120 ?? #3
If you called the company and they told you it would fit , what's the problem? If you don't trust the company why would you consider making any purchase from them?
Hi Rick,,, actually, your the one I was referring to regarding seeing it mounted on an L3400 ! By chance do you know how tall your rear tires on the Kubota ?? Yeah I read your posting and am familiar with the issues you had. Glad you've gotten them worked out. Thanks for the reply.
Jim:D
The problem is I've also been told by someone that sells them that it won't. In my opinion, both "should" be considered reliable sources. So, to save a little headache later,, I'm asking around !! It's not the company I don't trust, in fact it's not a matter of trust,,, perhaps one person is mistaken,, I simply want to be positive before I shell out $5-or $6oo bucks of my money.
   / Leinbach L7300 on JD 4120 ?? #6
I'll try to remember to measure the tires. BTW...you can get these on ebay for about $325.
Ok,, Thanks Rick !!:cool:
   / Leinbach L7300 on JD 4120 ?? #8
I checked my tires. They are 3' 4" tall and the Leinbach L7300 works on mine.
Thanks,
Rick
HYSTER 60FT WAREHOUSE FORKLIFT (A51242)
HYSTER 60FT...
Quick Attach Pallet Forks (A47384)
Quick Attach...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
