Posthole Digger Leinbach L-7200 Manual Needed
   / Leinbach L-7200 Manual Needed #1
billrigsby
florissant
Kubota
I just picked up a used Leinbach L-7200 Post Hole Auger,
I have searched high and low and can not find a user manual !
Can any one help ?
Thanks, Bill
thekubotaproject@gmail.com
   / Leinbach L-7200 Manual Needed #2
My searching leads me to a Leinbach notice stating they do not deal with customers but just their dealers and customers need to go to an authorized dealer for support and they recommend EverythingAttachments.com
Everything attachments does not mention Leinbach directly but look at the post hole augers they sell under their own name. Probably Leinbach products re-branded.
Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements.
Look over the pictures on the above link to see if you see yours. If you do email them and ask for a manual.
Do you have a specific question, type of lubricant perhaps.
There is a description of the 7200 which you likely have:
Confusion often arises in web sites because the information may be badly out of date and thus misleading.
The L7200 Leinbach Post Hole Digger is made with a tubular mast and yoke. The gearbox has tapered roller bearings, which run in lubricating oil. The gearbox control handle allows for the drilling of a perpendicular hole. The individual one piece cutting bit is replaceable. The four-position boom allows for adjustment to fit most category 1, 3 point hitch tractors. The output shaft is 2" round. The shielded PTO shaft has shear bolt protection. The gear box has a directing rod. This Leinbach Post Hole Digger is made for the full size and larger compact tractors, for use with up to 12" augers.
Dave M7040
   / Leinbach L-7200 Manual Needed #5
^^^^^^^This, they were based in Winston Salem, N.C. and moved down the road a ways and went out of business a year or two ago.
What do you need a manual for? If you have questions post them here, I am sure someone can help.
I got that link earlier from elsewhere but it did not work, must have had a typo in it
yours worked I also found another if any one needs it.
My email is thekubotaproject@gmail.com
   / Leinbach L-7200 Manual Needed #8
Bumping this back up, just got a Leinbach 7200. Is there a current source for the manual, or can someone talk to me about the gear oil viscosity/capacity to change the oil in the 7200's gearbox? I've watched some of the old Everything Attachments videos on the 7200, but he doesn't get into that type of maintenance. TIA.
   / Leinbach L-7200 Manual Needed #9
Bought in 2007 for $360 with 12" auger included!
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
BE 3 pt Snow Blower (A50514)
BE 3 pt Snow...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
