Legit Box Blade
/ Legit Box Blade #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
If anyone is looking for a legit box blade for their two wheel tractor, I came across this.
It's not on their website though, but interesting. It seems a lot better than a blade with ends on it.
Sent from my iPad using TractorByNet
/ Legit Box Blade #2
Hi! Very good ! I like the tractor As asian walk behind with steering clutch and track.
We need steering clutch with track. Heavy 400-500 lbs a lot a better puller than our BCS or Grillo
The box blade is heavy and tough built. and need a heavy tractor I think
Thanks for share Good luck! Oldmech
/ Legit Box Blade
How does the steering clutch work different than the Grillo or BCS units?
/ Legit Box Blade #4
Hi! BCS and Grillo have a differential. If we brake one wheel for turn .
Gears in differential add power and speed at the other wheel this one turn 2X more speed
No differential With steering clutch.
So if you press one lever the wheel come free no power and the other wheel turn at same speed as before
For turn we must free one wheel. If we press the two lever we stop the tractor but PTO run So you have a live PTO
AGRIA make a walk behind with steering clutch. Kubota and Yanmar make Asian tractors with steering clutch.
China makes a lot now.
Good luck. Oldmech
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2016 CATERPILLAR  730C (A63569)
2016 CATERPILLAR...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2012 DRAGON  130BBL VACUUM TRAILER (A63569)
2012 DRAGON...
1996 RWAY BELLY DUMP (A63569)
1996 RWAY BELLY...
2020 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2020 DRAGON 150...
