Left rear caster cracked MidMount Mower GC1725
   / Left rear caster cracked MidMount Mower GC1725 #11
Well I rounded a wet sloping spot and hung my rear caster wheel on the mid mount. Effectively it bent in toward the tractor/deck. Now it has a crack and is not structurally sound.
Has anyone ever had luck welding these and having it last or am I just hosed? Will definitely need to be bent back to position and ground but wondered if a stick welder would work. The weld broke on the arm that connects the axle housing/shaft height to the two aframe pieces. Not the weld to the deck.
It was a poor weld to begin with, no penetration. Grind off all the local paint and take it to a pro. If repair is done on the machine, disconnect Negative Battery Cable before Welding.
2015 KENWORTH T800 DAY CAB (A53426)
2015 KENWORTH T800...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
