LED work lights upgrade, Kubota Grand L cab.
   / LED work lights upgrade, Kubota Grand L cab. #1
lungdoc
Niagara & Muskoka ON
Kubota L6060 cab, Deere 4320
Just installed these LED lights from Larsen lights. Nice units and a good company to deal with. I wanted something that was fairly "plug and play" and that could use existing wiring, bracket etc. rather than go through a lot of hassles. https://www.larsenlights.com/led-845w - the 845-2 "easy bracket" model
Easy install - I just cut the wiring connector off the old lights and used the 2" of wire or so to crimp connect the new lights (which terminate in plain stripped wire). Had to add a few washers as the bracket was a bit wider than the mount point on the light but otherwise was super easy. Haven't used yet but the photos show what it looks like in the building. Prior lights were halogen Kubota work lights.
Old lights - photo with same manual exposure as below
New Lights
Old
New
One of each
   / LED work lights upgrade, Kubota Grand L cab. #2
Very nice! Do you have any pics of them mounted on the cab? I'm thinking of doing a light upgrade myself. Thanks.
No but can take some in the morning. They are just slightly bumping at the top against the roofline - so pointing very slightly downwards but I think will be fine and that may be the desire angle anyway. To be perfect I would need to modify the bracket to allow the light to sit about half an inch more forward. I also never found anywhere that would tell me the maximum wattage to keep existing switch and wiring, which was why I went with two lights and not a large light bar.
Here's the lights installed.
   / LED work lights upgrade, Kubota Grand L cab. #5
Thank you. They look great. I checked their website and these lights look like a quality unit. I like the fact that they pretty much bolt right on with the brackets that come with the lights. I'm going to put this on my "to do" list.
   / LED work lights upgrade, Kubota Grand L cab. #7
I agree - they look good. Thanks for posting that site.
gg
   / LED work lights upgrade, Kubota Grand L cab. #8
I've been considering something like this for my L5740.
Has anyone tried mounting some of these on the rear of the cab for working with an implement at night?
   / LED work lights upgrade, Kubota Grand L cab. #9
I mounted new LED;s on the front and moved the halogens to the rear.The wiring is in place you will need to purchase the "factory" switch.Easy job really.
   / LED work lights upgrade, Kubota Grand L cab. #10
How much did it cost for you to import these? Looking for something similar to this and I am located pretty close to you.
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
2025 JMR 66in Single Cylinder Grapple Rake Skid Steer Attachment (A50322)
2025 JMR 66in...
John Deere 4044M (A50120)
John Deere 4044M...
Swict 84" Bucket (A50121)
Swict 84" Bucket...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
