LED Lights
/ LED Lights #1
the whispering oaks farm
Imboden, Arkansas
LS XR4046HC, Ariens 60" max zoom zero-turn- Cub Cadet 1050 Rider
I installed a 22" led light bar and replaced the original OEM work lights that came with the tractor with LED lights, man what a difference! Now I want to replace the original headlights with LEDS. I looked up the headlight and work light numbers but it doesn't cross with anything that I could find so far. Does anyone have a headlight replacement number other than the LS numbers? I'm on a quest that could take a while. the original lights don't even look like they are on compared to the LEDS. :)
/ LED Lights #2
Do you have a picture of your light bar? And what brand is it?
I've been thinking about your backup camera and try to figure out where I could semi safely mount a camera so I could see what my bucket was doing better. I have one I was going to put on a truck that I traded in on a new one that already has a backup cam.
/ LED Lights
The light bar I used was (120W 24" LED Alloy Spot Flood Combo Work Bar Diving Light SUV | eBay) it was inexpensive and works great. One of the things you may consider and probably haven't run into yet is to build a frame for your work lights. they are only mounted to the front though the fiberglass shell and are not attached to any framework-I snagged a small branch and broke one of the lights off. there are two tabs by the mirrors and I made a frame to mount my work lights and also my new light bar to it. Lightbar.jpgI mounted my backup camera in the front grill and routed the wiring though the hood along the original headlight wires.
/ LED Lights #4
I also made my own light brackets (Front and Rear) after I read whispering oaks busted off one of his lights. I have the same LED Spot / flood light on the rear and moved the existing front cab lights and strobes to the new front bar.
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
New/Unused IRGC40 Mini Golf Cart (A65583)
New/Unused IRGC40...
Heavy Duty Power Line Winch (A65579)
Heavy Duty Power...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
2015 Ford F-650 Altec AP40 35ft. Bucket Truck (A64194)
2015 Ford F-650...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
