LED light bar for 1025R FILB
   / LED light bar for 1025R FILB #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
Finally added a new worklight to the 1025R ROP.
I had been bugged a bit by the way the FEL blocks the headlights on the few occasions I'd had to be working at night (& usually in bad weather ...) and wanted to mount something high enough to shine over it.
I picked up a 22" flood/spot combo LED bar via Amazon. Nominal specs are 40 3W emitters, w/ 16 on the outer edge being flood & 24 across the center being spot, 8.4 amp draw @ 12v. Supply voltage OK 10 - 30 volts. Caught it marked down to about $36 delivered via Amazon Prime & thought it was worth a try. (The product page at Amazon can be found here:
Amazon.com: Cutequeen Trading Universal 10v-30v Dc 120w 22" Rectangle 6000-6500 LED Spot Light for Tractor Marine Off-road Lighting Rv Atv(pack of 1): Automotive)
I ended up using a piece of 1/8" 1.5"x1.5" aluminum angle for the mount. A couple of holes for two 2" square U-bolts and two slots for the lamp mounting was all the fabrication required.
The wire got routed through the ROP, entering via the existing hole in the top. I ended up using some string trimmer material to fish through the tube & pull the wire through. Previous attempts let me know that there were some sharp edges present, so I used a double wrapped layer of electrical tape as a sheath over the pair of 14 AWG I used.
I routed it out through the hole in the side of the lower ROP tube & from there to the existing capped bullet plug pair for a rear worklight. I didn't locate these first, if I had I would have routed through the right side of the ROP rather than the left side since the pair are by the lower right side of the ROP. :banghead:
Any way, It works! When the switch is placed in the worklight position, the LED bar comes on along with the fender lights.
It turns out a 22" bar is the largest size that will fit within the upper ROP. There is just enough clearance that, if desired, I can loosen the allen screws on the side of the lamp mounts and rotate the light up & around to point to the rear if I ever need to use the backhoe at night...
Nick
   / LED light bar for 1025R FILB #2
Looks Good.
I have the same light on the front of my Rops also, I have have had it for a few years now with no problems. they throw a lot of light.
I also have square 50 watt flood led light for the rear of the Rops.
Here's what it looks like in the dark -
Headlights only:
Headlights + light bar:
The difference is actually greater than the photos show. The camera dials down the exposure time when the LED is on, making the picture look less bright - note the difference in how the instrument panel looks - you cannot see the backlighting at all in the LED - on pic and the gauge is sharper due to the shorter exposure. The shadow in the headlight only view was what I was aiming to eliminate...
Nick
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55315)
2017 Rogator...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
