led bulbs in bx2680 for signals / hazards
   / led bulbs in bx2680 for signals / hazards
   / led bulbs in bx2680 for signals / hazards #12
I have the dealer installed cab but not with the added lights so I'm installing them myself. Thanks for the picture. I think I may have ordered similar for the back.
The rear are Nilite's off Amazon, hard to beat for $13 a pair! Fronts are about $16-22 a pair
Sent from my SM-S921U using TractorByNet mobile app
   / led bulbs in bx2680 for signals / hazards #13
How do you measure the load on LED lights? Thought I would add extra lights but don't want to overload the 10-12 amp circuit.
   / led bulbs in bx2680 for signals / hazards #14
An amp meter, but I recently bought one of these https://www.harborfreight.com/30-amp-fuse-slot-circuit-amperage-draw-measurement-tool-70079.html and find it incredibly useful.
I've been using it to track down a parasitic drain on my dads truck but was curious what the actual draw was on the new work lights.
   / led bulbs in bx2680 for signals / hazards #15
Do you have a canopy? This is what I did on my bx2680 for lighting.
Front:View attachment 4330664
Rear/side:View attachment 4330665 (there is a pair on each side)
Fantastic light coverage! Total load is 8amps measured.
I've got the same exact lites you do, I had the longer ones bolted on a home made bracket on my loader for 4 or 5 years but never got a chance to hook them up, lol. One oem bracket did break from the vibration and I assume a branch or two. I have a box of 10 of the small ones to go on different machines.
I'm looking to to put a canopy on both the tractors but can't find a longer one to cover the back more. Going to camera's soon and want a dry place to put the monitor.
For those that don't know, LED lights do put out quite a fair amount of heat believe it or not. Either at the "bulb" end or at the base.
Something you may run into is the lens on your vehicle/machine -may- not filter the light the right way, so your red lens with a white LED may show pink or even a whiteish light. This is mostly on the older vehicles as the new ones are going to LEDs more and more anyway. That's why it's suggested you put a red LED in a red lens, amber LED in an amber lens, etc.
Just a very broad explanation of LEDs, LEDs put out something like 98% white, or red or amber light, and normal lites put out 75% of the white, red or amber light, the rest is a combination of the other colors.
   / led bulbs in bx2680 for signals / hazards #16
For my tractor, LED's are a direct swap. The hazard and turn signals are probably 3X as bright in daylight; retained normal flashing.
I swapped all signal / flasher bulbs to led this morning on my BX2680. All flashing functions work as normal. There isn't any hyperflashing. Certainly brighter than the original 1156 and 1157 incandescent bulbs with less draw.
   / led bulbs in bx2680 for signals / hazards #18
For anyone that put led bulbs in the amber signal /hazard lights on a current model bx80, did they hyper flash needing a resistor or different flasher relay?
to move to LED bulbs you need a LED flasher. I did that to my tractor and to one of my cars. otherwise the y won't blink due to LED's don't put enough load on a regular flasher to activate it. you can get a LED flasher from Amazon
   / led bulbs in bx2680 for signals / hazards #19
Some users have reported melted wiring on vehicles replacing bulbs with LED's.
I've experienced that on any older car. I did change them all on my Kubota BX2680 and no issues. The factory flasher unit works fine.
Hyster H80FT 8,000LB Forklift (A56857)
Hyster H80FT...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
Hydraulic spike driver (A56435)
Hydraulic spike...
2013 International WorkStar 7500 Altec D3060BTR 60ft Insulated Digger Derrick Truck (A55973)
2013 International...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
