OP
CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,019
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
LED lamps, even multiple lamps should never be able to draw more power and blow a fuse that was originally spec'd. for an incandescent. I imagine you would have too much light and go blind before the fuse would let go. Alternatively, I recommend running a low voltage/amperage/wattage switch to a relay direct connected to the battery. It will be fused separately and even if your lights blow, you won't harm the main electrical of the tractor.
For my requirements, it's not an issue of current carrying capacity of the fuses (there are none) or wiring. It's strictly supply and demand.
If I run the "standard" 35W headlamps, The battery will not come back in any reasonable operating time after using the electric pump to move the front Western snow plow. Taken to the extreme of pushing back banks after a series of winter snow storms, and it can bring the battery down to where the pump motor get's sluggish.
Sure, I keep a battery charger for when it is required. And I could save the "big pushes" for daylight hours.
But if I can have lights and more amps available just by making an informed LED light choice. Win! WIN!
There has been one reply that has been very informative to the original question. That helps a lot.
I am sure others have different questions needs and solutions.
It's good to get all the comments ;-)
