Buying Advice learning to value used tractors for foodplot
   / learning to value used tractors for foodplot #1
Lundeye
none
have grizzly atv need to till, brush, log,
and dress road
   / learning to value used tractors for foodplot #2
Just what kind of info are you looking for. You need to explain better what you are asking. Are you buying/pricing something? Do you want to compare something? Are you using your ATV for this? need more than what you posted please
   / learning to value used tractors for foodplot #3
need to till, brush, log, and dress road
Like many here, I do all those things. First question is how many acres will you till? How many acres will you brush cut (rough cut? ). How long and wide is the road. What is the road made of? Dirt, clay, sand, loam, gravel, or?
While many would concider it too small, I use a 35 hp 4wd tractor and mostly 5' implements and have over 200 acres of woods. For many things a larger tractor would be wonderful, but for going between the trees, not so much.
   / learning to value used tractors for foodplot #4
Also how much will you be willing to spend as we here love to spend your money a lot more than you:laughing:
Would you be looking new or used?
How many acres?
What kind of land is it? clay? sand?
I would look at around 30HP if your looking for what I think.
Please provide more info and we'll be sure to add more.:thumbsup:
Just a 1 acre foodplot, 15 acre clay in crp to brush around. 1/4 mile road along a limestone bluff in SE MN. Cut some firewood.. Need wide wheel front for the hills.
   / learning to value used tractors for foodplot #6
and dress road
Welcome to TBN.
So are you looking for implements for that ATV, or for a tractor, or what?
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56435)
2006 Tusk 500...
John Deere 4600 (A53317)
John Deere 4600...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
