Buying Advice learning to value used tractors for foodplot
   / learning to value used tractors for foodplot #1
Lundeye
none
have grizzly atv need to till, brush, log,
and dress road
   / learning to value used tractors for foodplot #2
Just what kind of info are you looking for. You need to explain better what you are asking. Are you buying/pricing something? Do you want to compare something? Are you using your ATV for this? need more than what you posted please
   / learning to value used tractors for foodplot #3
need to till, brush, log, and dress road
Like many here, I do all those things. First question is how many acres will you till? How many acres will you brush cut (rough cut? ). How long and wide is the road. What is the road made of? Dirt, clay, sand, loam, gravel, or?
While many would concider it too small, I use a 35 hp 4wd tractor and mostly 5' implements and have over 200 acres of woods. For many things a larger tractor would be wonderful, but for going between the trees, not so much.
   / learning to value used tractors for foodplot #4
Also how much will you be willing to spend as we here love to spend your money a lot more than you:laughing:
Would you be looking new or used?
How many acres?
What kind of land is it? clay? sand?
I would look at around 30HP if your looking for what I think.
Please provide more info and we'll be sure to add more.:thumbsup:
Just a 1 acre foodplot, 15 acre clay in crp to brush around. 1/4 mile road along a limestone bluff in SE MN. Cut some firewood.. Need wide wheel front for the hills.
   / learning to value used tractors for foodplot #6
and dress road
Welcome to TBN.
So are you looking for implements for that ATV, or for a tractor, or what?
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
