Learning to operate a grain drill, at night, in wet ground, right before a storm...
   / Learning to operate a grain drill, at night, in wet ground, right before a storm... #1
dixiedrifter
I was busting my tail trying to get some wheat planted before it put into raining last night.
There was just enough light to get it around the field about 3 rounds before it got dark enough to require lights. Then about an hour later, it started lighting off in the distance, but I kept on chugging.
The ground was pretty wet too, and I was afraid if I didn't get done then it would be god knows how long before the ground would dry out enough to get back over it since a couple weeks ago we got 10"+ inches of rain over a period of 5 days.
I managed to get halfway done before I ran out of diesel right there in the far end of the field right before the weather started to get rough enough that I was going to head in because the lighting was getting too close for comfort.
I made a mad dash for the house and made it back OK, and it turns out we only got maybe a 10th of an inch of rain, if that, while about 10 miles down the road it came a torrential downpour.
Went out today and looked over the field and finished up planting. Didn't have any trouble getting the tractor to crank since I cut it off as soon as it started to die. All things considered I think I did a pretty good job, and I passed grain drill school.
Tractor did great, 4WD Kubota M9000, was running in 4th low and was hardly straining with the 8000lbs it was pulling @ 500lbs down pressure. On the road it easily handles the weight in 8th gear @20MPH.
It will be interesting to see how well the wheat comes up.
   / Learning to operate a grain drill, at night, in wet ground, right before a storm... #2
Re: Learning to operate a grain drill, at night, in wet ground, right before a storm...
Pictures would make my day, how about the rest of you ? I understand, you didn't have time
Good luck
Jim
   / Learning to operate a grain drill, at night, in wet ground, right before a storm... #3
Tell me more about your grain drill. Make? Model? Bin capacity? At 8000 lb that device must be really big. What's the down pressure doing?
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
TEXAS PRIDE TRAILER (A53843)
TEXAS PRIDE...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
