Buying Advice Leaning toward Kubota B2601-- what else should I consider?
   / Leaning toward Kubota B2601-- what else should I consider? #21
Lots of good advice. Based on your usage, I would seriously consider the L2501. I have a B2620 have been very happy with it. I don't believe the discount Ls had hydrostatic transmissions when I bought mine, and my trailer wouldn't have handled a bigger tractor.
I would like an L, but not enough to consider a trade unless I was able to afford a L 3901 or bigger-I have gotten into planting food plots and would like the extra power and weight.
Will
   / Leaning toward Kubota B2601-- what else should I consider? #22
<snip>and my trailer wouldn't have handled a bigger tractor.
<snip>
Will
Will brings up a good point - How will you move your tractor over a distance? Consider if the dealer picks up and delivers, rental of a trailer, or purchase of a trailer.
Rental can sometimes be a problem because a lot of trailer rentals may not be big enough for 50HP plus tractors, I've had that problem with my M4700.
Purchasing a good 10K or 12K trailer is usually about $2K to $3K, but then you've got a trailer whenever you need it.
   / Leaning toward Kubota B2601-- what else should I consider? #23
I have a B2920 (similar to B2601) on 16 heavily wooded acres. I do all the things you have listed with it except clear snow (not much need for that where I live). You are not going to lift large logs with the FEL but you can drag them (loaded tires are helpful). I have a lot of privet hedge, some that can be bush hogged and some(~ 6" diameter trunks) I have to push over with the FEL to be piled up to burn. The privet hedge is not deeply rooted. A L2501 would probably do this job faster just due to the extra weight. A lot of it depends on how fast you need to get some things done. The B can probably take care of business for you but an L2501 can do some things faster and will lift more.
Thanks so much for all of your helpful suggestions and feedback! We'll seriously consider the L series.
   / Leaning toward Kubota B2601-- what else should I consider? #25
Get next lager size machine
PALLET OF 250 TRAFFIC CONES (A58214)
PALLET OF 250...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Bucket (A55973)
Bucket (A55973)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
