Rotary Cutter Leaky seal in bush hog squealer
   / Leaky seal in bush hog squealer #1
Lucedale, MS
MX5000 4WD
Well, I have been using it pretty hard lately and my bush hog is leaking out of the bottom seal now. What is a fair price to expect to pay a shop to change it?
I have installed gears in cars before, would this be something I could possibly do myself or is there a bunch of special equipment required?
   / Leaky seal in bush hog squealer #2
A lot of people just pump the gearbox full of grease with a little gear oil. The thick mixture wont leak by the seals.
   / Leaky seal in bush hog squealer #3
I usually do the grease and oil mix. The only mower that I have ever had that I can keep seals in is my 15' Rhino batwing, my 6' Rhino lasted about 2 years till it began to auto change the oil. I use grease in my 6' mower and still use oil in the 15'. Been doing this for years with my 3 PH mowers.
   / Leaky seal in bush hog squealer #4
My uncle, an old farmer, always used a mix of diesel and grease in his gearboxes.
I bought an old mower from him once, and cleaned out the gearbox and put gear lube in it, it poured out the bottom as fast as I poured it in.
So I put the grease and diesel back in it, and never had any problems.
   / Leaky seal in bush hog squealer #5
A few months ago I took my gear box off and in to the dealer for repair. They replaced both seals for $65. Of course it would be higher now. Don't know if it is something I could have done but for that price it was worth it.
   / Leaky seal in bush hog squealer #6
How old your Squealer is? It should be covered by the 5 year warranty, if it's not too old. How bad is your leak? I have a Squealer too, now I'm getting worried about leaks.
Just looking at it, it looks like a straightforward job to change the seal. The devil is in the details, getting all those big bolts broken loose.
   / Leaky seal in bush hog squealer #7
A 5 year warranty on a bush hog???
   / Leaky seal in bush hog squealer #8
Grease er up, I've had leaky seals in my brush hog since I bought it used about ten years ago. I'm guessing it is around 15-20 yrs old, no problems...I fill it at the beginning of each season.
2013 Ford F-150 (A53422)
2013 Ford F-150...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2003 Nissan Xterra SUV (A55853)
2003 Nissan Xterra...
