leaky rear trans @ front axle e2004
/ leaky rear trans @ front axle e2004 #1
shady1701
my propshaft running from rear of trans to front axle is leaking i was wondering where the seal was and is ? any diagrams for e2004
/ leaky rear trans @ front axle e2004 #2
There is a flat gasket between the driveshaft tube and the trans.
Eugene
how would you get the driveshaft out does it have a u-joint at front and like a slip joint going into transmission?
/ leaky rear trans @ front axle e2004 #4
Take the front axle pivot pin out and drop down to clear botton of tractor. Remove bolts on rear tube flange and pull forward. It will slip right out. The gasket goes behind the flange.
Eugene
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2022 EZ-GO ELITE...
2000 Volvo Semi Truck (A66285)
2000 Volvo Semi...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
