Leaky quick-connect... common? What to do?
   / Leaky quick-connect... common? What to do? #11
I had the same problem and solution as Red_rider. Got new couplers and it solved the problem.
Those couplers can be expensive. A set of two large ones from my dealer are $75. Smaller ones are about $50.
Later,
Dan
   / Leaky quick-connect... common? What to do? #12
I had the same problem with my 7800 from trying to shove it on. I damaged the O ring inside the coupler. I couldn't just buy the O ring. $17 later, I learned to be more careful. Before replacing your coupler, make sure you release any pressure in the system as not to get injured withy hydraulic fluid. Also make sure all implements are on the ground just in case.
   / Leaky quick-connect... common? What to do? #14
</font><font color="blue" class="small">( I had the same problem and solution as Red_rider. Got new couplers and it solved the problem.
Later,
Dan )</font>
You can buy the Parker standard connector at any farm supply store for $15 or less. Dealers & OEM gouge people....
It will be made by the same people, either place you buy it....
The O ring to fix your old one would have been about 50 to 90 cents.
And yes, O rings are available. Maybe not from a dealer that wants to gouge people - but from honest folks, the O rings are _available_. I go through several a year on all my tractors & hyd equipment.
--->Paul
2024 Electric Intimidator UTV (A59814)
2024 Electric...
New Holland 308 Manure Spreader (A59814)
New Holland 308...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Sakai SW354 (A60462)
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
