Leaky New TC25D with No Headlights
   / Leaky New TC25D with No Headlights
Thanks for the heads up, Kent. I'm going out there to do the job today. Since I already found one cross-threaded bolt on the MMM, I am concerned that there may be a problem with this too. If it is cross-threaded, I'll just make it worse, and it it's not, there is always the danger of too much torque and stripping either the female or the male.
I'll post to say how it went.
Thanks Again,
Jim
   / Leaky New TC25D with No Headlights #12
You're welcome Jim, I hope it works out for you. Really makes you mad, having the equiptment, and not being able to use it. Kent
   / Leaky New TC25D with No Headlights #13
Jim:
Sorry to here about the 'gotchas...add enough up and they can take some of the fun out of the purchase I know.
Regarding your lights, I had a similar problem with lights on my TC45D.....no headlights...fuses were fine and wires at headlight were tight/connected. Not sure if the wiring harness is the same between the tractors, but discovered a connection (about 3/4 of the way back from the headlights to the fuses). Its a covered connection, but had 'loosened' Pushed em together and presto....lights!
Indiana Paul
That was it, Paul - except somehow dirt got in there. I blew it out, and now there are lights.
Thanks for the tip!
Jim
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
