Leaky loader hydraulic hose coupler....
   / Leaky loader hydraulic hose coupler.... #1
spruce Deere
Veteran Member
Northmost Idaho
John Deere 790 with loader LS xr3140h also with loader plus a cab
Unloaded some firewood logs monday with the XR 3140 and when I parked the tractor I noticed the quick coupler for the bucket curl up function hose dripping, complete with an oil trail right to were I parked.
So, I undid the quick coupler, could not see any crud or any o-rings wanting to leave or that had left there position inside the female half, and the male half of the coupler to be pristine, barely even could see where the 'lock balls' rode on the ridge to keep the two halves together.
Blew out the female half with some brake kleen and compressed air, brake kleened the male then stuffed the two back together and now no leaks....
I have not had the loader off the tractor since new and that was fist time I even undid any of those couplers.....
Anybody elts run into this with there LS machines??
   / Leaky loader hydraulic hose coupler.... #2
Yes, I have. I called my dealer, who had no suggestions (learned that they had no idea which brand of quick disconnect fittings were installed - mine are Stucchi), then did the same sort of maintenance the you did, although the first time I tried, the fitting still leaked, but the second try worked. I think that it takes very little grit to cause a leak - my second time, I focused on o-ring cleanliness.
My only conclusion so far is that the convenience of quick connection is not a perfect trade-off so far for me.
Hope this helps a little.
   / Leaky loader hydraulic hose coupler.... #3
be careful using brake clean on any seal. It can cause swelling.
Thanks johnT3383, that helps alot.
They are not a perfect trade off and such things happen.... Like just out of the blue to start leaking like it did, even without ever separating them in 4 years.
I will look into getting a couple spare couplers anyhow....
   / Leaky loader hydraulic hose coupler.... #5
Brake kleen will not hurt the o-rings. the material they are made of is not affected by it.
Still leaks....
Mt40233022 female coupler
Mt40228720 male half
40-ish bucks from newholland for both
2019 PETERBILT 379 DAY CAB (A45678)
2019 PETERBILT 379...
More info coming soon! (A46683)
More info coming...
2017 Ram 1500 4x4 Crew Cab Pickup Truck (A46684)
2017 Ram 1500 4x4...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
1998 MACK CH613 DAYCAB WINCH TRUCK (A48992)
1998 MACK CH613...
Kubota 74in 1.5 Cubic Ft Bucket (A46683)
Kubota 74in 1.5...
