Leaky front axle
/ Leaky front axle #21
Like your vent. Venting the axle is a good point. My 80s era M5030 front axle was leaking some. Especially after bush hogging or transporting trees/brush. Hillside farm you stay in 4wd. Didn’t have a dipstick, only fill and fluid level plugs. Made vent tubing filter/plug for the fill port. No more leaks for 20 years till I sold it.
Newer tractors have plastic dipstick plug. Not sure how or if they vent. Do the newer tractors front axles have a vent?
My 2021 Bobcat CUT has a vented front axle. Plastic threaded plug with steel dip stick.
/ Leaky front axle #22
What about removing the tire,then remove the 8 bolts that hold the axle flange housing.
Take the assembly to the dealer for a bench job?
Good Luck!
/ Leaky front axle #23
Just for general info. I tried some seals off from Ebay that were about a third of the kubota price. Worked ok for a couple of months, then started leaking.
Like the cheap Chinese water pumps. Look good but aren't worth beans. Like i's been said, the bad taste hangs around long after the cheap price wears off. I only use genuine Kubota seals and filters and always have.
Far as venting a front axle. there is plenty of free air space in the axle to allow for fluid expansion so long as the axle isn't overfilled. I have 6000 hours plus on one of my M9's and the front axle has never weeped a bit. Ain't mo vent that I'm aware of either.
/ Leaky front axle #24
My 1985 L3750 4wd leaked at the front axle seals.At the dealers suggestion I drained the 80/90 and filled with corn head grease.Heavier viscosity ,no more leaks. Simple fix no side affects.
/ Leaky front axle #25
If it ever leaked again just pump it full of axle grease - that ought to fix it for good!
/ Leaky front axle #26
Sure enough.
Maybe that's what they should have in the first place.
Then no more leaks. Stupid engineers.
Transmissions, too. Same parts in there.
/ Leaky front axle #28
In reality when there is a dead air space above the lubricant in the front axle so as the fluid warms it can expand. If correctly engineered, no vent needed.
/ Leaky front axle #29
All the above plus you need to have a look-see at the king pin and king pin bushings, especially if you do a lot of loader work. Easy to replace as well. drive them out with a suitable sized drift and drive the new ones in.
For some reason (I suspect manufacturing cost), Kubota likes to use ball bearings in the outboards instead of Tapered rollers which do0a lot better job of bearing the weight imposed by a front end loader, because tapered rollers distribute the weight a lot better and have a wider contact point than ball bearings.
If you king pin bushings get worn, that will cause the radial seal to leak as well. Just replaced the left side on my 6000 hour M9. Easy to tell too. Loft the front end, taske the wheel off and grasp the outer flange and try to move it vertically. If it moves at all it can be the bushings, or the king pin or both. Good time to check the front axle pivot too for excessive slop. It needs to move free in an arc with no lateral movement. Owners tend to forget about greasing the pivot and checking the pre load. Your owners manual details how to set it using the front bolt and jam nut.
There are no kingpins or bushings, more FAKE INFO.
/ Leaky front axle #30
So tell us oh hallowed one, what keeps the upper and lower knuckle aligned? Last time I checked it was a kingpin and upper and lower bushings but then maybe you know better. I know, faith keeps them in place right?
/ Leaky front axle #31
Look it up yourself, you need the education apparently. The L series design is different than the M series but you think you are an expert on such things.
/ Leaky front axle #32
I don't know what is the design of L3430 front axle, but I recommend to take into account another possible reason of failure. In the below video, at the point of 1:29 take a look at a crack which may cause oil leak too.
/ Leaky front axle #33
My CK2610hst began leaking at the front axles. Upon looking at the dipstick I see it is vented (see the small hole on the side). Took the dipstick to my shop and used compressed air to try and blow out the crud that looked to be in this small hole. This popped off the top round disc that is pressed into the top of the dipstick, indicating there was no air flow thru the vent. Inside the dipstick there's a gray foam filter, which was jammed in there so tight it was preventing any flow. I removed the gray filter and after an oil refill I'm going to run it without the filter to ensure good flow. Remains to be seen if this is the cure... will update later. So, good idea Kioti for having a vented cap... bad technique for cramming an oversized filter in there to block all flow!
/ Leaky front axle #34
May just have some junk packed around seal. Clean it out.
/ Leaky front axle #35
Could it be that the filter allows plenty of flow to equalize the barometric and temperature pressure changes that the front axle sees? Those things don't change very fast or result in much volume. Compressed air is a whole different animal.
What else might cause a front axle leak?
rScotty
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
KJ K4525 45'x25' Double Garage Barn Shed (A60463)
KJ K4525 45'x25'...
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
(INOP) MASSEY FERGUSON 543 TRACTOR (A59823)
(INOP) MASSEY...
AGROTK YC-32G Horizontal Band Saw (A60463)
AGROTK YC-32G...
