Leaky battery
   / Leaky battery #11
I upgraded to an Exide cylinderical cell battery (purchased from Sam's Club) before any leakage issues developed.
Picture attached....
Don
   / Leaky battery
That would have been a great idea and it turns out that after a bit iof searching on this forum I should have been warned since there are many examples of this happening, even on Kiotis.
I just bought an orbital AGM battery made by exide, a starting battery with 1000 CCA, black just like yours TBDonnely but a newer model, for a whoppin 111$ at Napa about 5 minutes ago. I am glad to see it will fit in the hole and the wires will reach though I was pretty confident. Too bad the terminals are switched, the battery will have to sit in their backwards with the label facing the radiatior.
The Napa guy charged me a 5$ core charge and says he will take all 14 of the batteries I have found on my property. I will keep the walmart battery for a backup after I check the acid levels.
The "OEM" battery only had 720 CCA while this one with 1000 CCA at 32 should give me great performance.
   / Leaky battery #13
Highbeam,
Any chance the blown fuse for the meter has anything to do
with the battery boiling? I think you were talking about
an ampmeter or voltmeter on your tractor.
   / Leaky battery #14
Sorry, when I re-read your post, I got the message. you
were talking about a handheld meter.
   / Leaky battery
I have a handheld multimeter that I can use to verify the proper output voltage from the running alternator. If the voltage is too high it will actually boil a battery's acid causing gasses to come out and acid to boil over. Might cause the battery to explode too. I blew the handheld meter's internal fuse by using the multimeter to measure volts but had it on the amps setting and the internal fuse isn't real common for replacement. I'm not real sure if the Kioti dash mounted idiot light will alert me to a high voltage situation.
I'm a home watching the girls tonight while momma teaches ballet so I won't be able to swap the battery until tomorrow.
The pic shows why I need to keep a close eye on them. Trouble they are.
   / Leaky battery #16
I raised two girls, enjoy them now, they become teenagers all too quickly. /forums/images/graemlins/grin.gif
   / Leaky battery #17
The manufacturer claims the orbital batteries are completely leakproof and will actually work underwater. This got me to thinking..... /forums/images/graemlins/smirk.gif
See attachment..... /forums/images/graemlins/grin.gif
Hmm..........
Caution: Do not try this at home!
Don /forums/images/graemlins/tongue.gif
   / Leaky battery #18
I'm not to sure if I'd trust the dash light either. That's why they are called idiot llights. They usually go off when something has totally failed. My battery is from the New Castle Battery Co., put in by the dealer and says it's a sealed type. No leaks yet with 97 hours. Maybe you have one of the cells going bad in your battery if your charging voltage is correct. It might be worth having it tested. Maybe one other choice for a battery. I have a cub cadet lawn tractor for mowing grass and went to Walmart for a battery. It uses a full size battery instead of one of those little ones. I found a battery that had a molded in pipe for a hose connection so any boilover could be run down to the ground. That might help but doesn't explain why yours is leaking all the time.
   / Leaky battery #19
</font><font color="blue" class="small">( The manufacturer claims the orbital batteries are completely leakproof and will actually work underwater. This got me to thinking..... )</font>
You are too funny Don. You always come up with some good photo editing.
The battery lasted, but the oil was screwed!
John
   / Leaky battery #20
Usually the leaking is actually boil-over from being overcharged.
KO
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
2018 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 FREIGHTLINER...
