Leaking Tire Tubes?
   / Leaking Tire Tubes?
Nope, no black locust trees here. I get your point however. I will run my hand inside the tires before I go to clean them tomorrow.
   / Leaking Tire Tubes? #12
My dad always used an old rag to check the inside of the tire, It will catch on anything in there, plus it might be less painful than dragging a hand across a nail or thorn!
   / Leaking Tire Tubes? #14
I had a leak at the valve stem. I have this little valve kit with a twist tool key. I just tightened the inner valve. If it's bad inner valve it can be replaced easily.
Yeah, that would have been nice. Its a hole in the tube somewhere instead. Of course.
   / Leaking Tire Tubes? #16
Pump up the tube. Find leak and find match on tire. Of course if you did not index the tire to the valve stem hole then that trick does not work. Also be aware that if the tire has a slight cut a new tube can start leaking soon. You can get fabric reinforced patches for the inside of the tire that can help if it has a slice. Or you can get the tire professionally applied hot vulcanized patch.
Another good idea but no, I did not index the tire to the stem.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
BUNDLE FENCE PIPE (A51244)
BUNDLE FENCE PIPE...
John Deere 7720 Turbo with Head (A52128)
John Deere 7720...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A52128)
2018 Dodge Ram...
John Deere (A50322)
John Deere (A50322)
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
