leaking rear tire
   / leaking rear tire #1
Crw
Farmall 140
I just bought a new kubota and it seems that I got a small leak in my side wall of one of the rear tires is there a simple fix for this will a plug work and if so do I have to empty the tire they are full of rim guard
   / leaking rear tire #2
If it's brand new, then have the dealer fix it.
I'm pretty sure slugs do not work in sidewalls. Probably you would need to have a tube put in. I have had to do that on a front tire.
   / leaking rear tire #3
i wouldn't plug a sidewall either. a patch from the inside may or may not work depending on the specific cause of the leak.. if too much trouble...i'd tube it, if I had to work on it vs the dealer.
2003 International 4200 Box Truck (A51692)
2003 International...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2023 John Deere 8R 410 Tractor (A53342)
2023 John Deere 8R...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
