Leaking Quick couplers
/ Leaking Quick couplers
So next time maybe cable tie a couple of small plastic bags to the entire cluster of stationary QD caps to keep them from getting ripped loose/off.
Take one of the other QD's O-rings to a local auto store, they should have a selection to choose from, or a hydraulic shop or tractor dealer......
Yep lesson learned on the dust caps. I run it down in my land in TN mowing the CRP fields with no problems with the dust caps on. This was my neighbors field up here in PA that I was doing for him. If I do his field again I am just going to leave the FEL on. I tried tying a gallon heavy duty bag around the cluster when the first 2 caps got torn off. Briars tore the bag to shreds.
I'll pull one of the other o-rings like you suggest and buy a bag of them once I match them up.
Thanks to everyone for the suggestions.......I heard you Sawyer Rob...WD40
/ Leaking Quick couplers #12
Yep, WD40 is also what I use all the time.
I use it B4 and after,
Replacing O-rings is an easy task also.
I also spray my PTO couplers with it both to flush out dirt as well as to lubricate.
A can lives in my tractor tool box.
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
