jwcinpk
Veteran Member
- Joined
- Aug 4, 2003
- Messages
- 1,155
- Location
- Welfare Capital of the World...KY
- Tractor
- 2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
The new 7010 has sprung a leak. Hydraulic fluid is pouring out of a bolt in the loader valve block. The bolt is plenty tight. It seems as though the gasket or O ring beneath the bolt is faulty. On the outside of the valve block there are 2 what seem to be plugs. They are about 3/4". The bottom one is pouring.
This happens at the most inconvenient time because my truck is broken down too. Do any of you know whether this is a gasket or an o ring behind these bolts? I geuss it's possible it's a machining defect and a gasket won't fix it.
