Mowing Leaking Lift control Block on my BX2230D
   / Leaking Lift control Block on my BX2230D #1
torrin
Stanwood, MI
Kubota B2650HSDC
Good morning;
I recently purchased a BX2230D. The previous owner told me there was a "small" leak when you raised/lowered the MMM deck and left the lift control out of the neutral position. He stated that he could not find the leak, but it left spots on his garage floor.
I found the leak. It is coming from the control valve and or lift block. The is a block that attaches to the valve and controls up/down of the MMM. I replaced the O-rings, removed and reinstalled the fittings and the leak is still there.
There are no obvious cracks in the control valve or the block, the leak is of such a volume that the crack (if any) should be obvious, and no cracks in the fittings. the leak is not getting better or worse.
I'm stumped. Any Help would be greatly appreciated.
   / Leaking Lift control Block on my BX2230D #2
Just a thought, could the leak be coming from above the control valve and running down to that?
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
2017 Kubota M7-151 Premium MFWD Tractor (A55315)
2017 Kubota M7-151...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
2020 Chevrolet Equinox AWD SUV (A55853)
2020 Chevrolet...
