Oil & Fuel Leaking injector pump on a 4020
   / Leaking injector pump on a 4020 #1
TheMacGyver
Eakly, Ok
John Deere 4020, Kubota 3350
I have a 1964 4020 that has started leaking fuel from a small ,looks like a bleed hole. It is "spurting" out of the hole. Anyone have any suggestions for a quick fix or is it pump time.
   / Leaking injector pump on a 4020 #2
I'm unaware that a 4020 inj pump has an "open bleed hole". Can you post a photo of your pump?
   / Leaking injector pump on a 4020 #3
Likely a vent hole which means you have an internal seal failure. Shop time is bet. A picture would help though.
   / Leaking injector pump on a 4020 #4
I'm trying to remember which pump was used on 4020's. If it is a rotary pump there are umbrella seals around the removable main shaft that are not too bad to replace. Requires pump removal and the knowledge of timing the pump to the engine on re-install.
   / Leaking injector pump on a 4020 #5
'64 JD 4020 utilized JDB inj pump. JDB had umbrella seals but faulty umbrella won't cause pump body to leak fuel
1268 (A50490)
1268 (A50490)
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
John Deere 1025R Tractor (A50514)
John Deere 1025R...
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2015 DODGE RAM...
