leaking hydro coolant line 2009 CT 235
   / leaking hydro coolant line 2009 CT 235 #1
lilranch2001
Super Member
Bobcat CT 235
I have a leak in my hydro system, it appears to be leaking past the o rings on this banjo bolt. # 25 & 26 (I think)
Anyone have any ideas if I am on the right track?
It is leaking at a rate of about 1 drop every 3-4 seconds
I have never worked on something like this, it appears to be an easy fix, but you know about assumptions!
   / leaking hydro coolant line 2009 CT 235 #2
Just wipe it good and clean and make sure the line is not cracked and joint bolt is tight. If not, then likely the O-rings.
Thanks Winston1, I wiped it down several times yesterday, could not see a crack, made sure the bolt was tight, could not get any more on it so I am assuming o rings.
Do you know if I will drain the tank by removing this bolt?
   / leaking hydro coolant line 2009 CT 235 #4
I do not know anything definitely, but I don't think you will drain the tank. Fluid only flows through that line when tractor is running. I can only guess a small amount will come out but again, no warranty from me. I do know that fitting is below the fluid level in the transmission but I am thinking going through the hydrastat housing may prevent a free flow of fluid. Also seems strange to me for that fitting to begin leaking. Any possibility it hit something while working your tractor?
Yea, all your comments have run through my mind.
The line looks immaculate, if it got hit by something it did not leave any evidence.
I picked up a half dozen o rings from Bobcat today, I may tackle it tomorrow.
The opposite side has the same o rings, so I may be needing them soon.
Hopefully there is no crack in the line I cannot see!
Thanks for your help!
   / leaking hydro coolant line 2009 CT 235 #6
Be sure and update us, please. Gotta know what happens now!
   / leaking hydro coolant line 2009 CT 235 #8
It wasn't a big crack...
Well as usual, you guys were smarter then I was
I should have ordered the tube Monday
   / leaking hydro coolant line 2009 CT 235 #10
If that crack doesn't go real close to the o-ring sealing area it could likely be welded. I know I would give it a try. That is likely an expensive line.
2018 Jeep Grand Cherokee SUV (A55853)
2018 Jeep Grand...
2022 FORD F-250 XL SUPER DUTY (A55745)
2022 FORD F-250 XL...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
LAYMOR BROOM SM300 (INOPERABLE) (A55745)
LAYMOR BROOM SM300...
TRANSMISSION FLOOR JACK (A55745)
TRANSMISSION FLOOR...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A53422)
2015 Peterbilt 337...
