Leaking Hydraulic
/ Leaking Hydraulic #1
rbcsaver
NE Pennsylvania
Deere 4320 & Kubota 7510
One of my FEL (7510) hydraulic disconnect fittings is leaking. The dealer didn't adress it when asked to, while under warranty. My brother said that there should be an O ring just above the bearings. Unfortunately, I'm not at home for a few days to see if that is the problem. Anyone know if there is an O ring inside the female connect and the size? Hate to pay dealer rates for and O ring that I can get elsewhere. Thanks for your help
regards, Steve
/ Leaking Hydraulic #2
Yes, there is an o-ring in the female connector past the ball bearings. If there is the slightest deformation, dirt, or nick it will leak. I had to pull my o-ring out, clean the sand out of the groove, and all was fine. Yes, you can get debris under the o-ring too...
Joe
/ Leaking Hydraulic #3
Any tractor dealer shuld have an assortment of O rings if you have to replace it. Just take the old one in and they can match it up, those things are pretty much standard sizes.
Bill Tolle
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
2022 EZ-GO ELITE...
2019 Ford Fiesta SE Hatchback (A64557)
2019 Ford Fiesta...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A64553)
2025 Wolverine...
