Leaking hydraulic valve
   / Leaking hydraulic valve #1
BarryC
Davidson, NC
Yanmar 1610D
The valve in the pic is leaking around the stem that is exposed. When I move the lift up and down without the tractor running there is a small bubble that appears during this some of the time. What is this valve called? and can I take it apart and replace the gasket or does the whole valve have to be replaced? Hoye has them for $250 but I'm hoping to get it fixed with a new gasket rather than a new valve.
Hi Winston, the stem with the red lever isn't where the leak is. It is happening around the piston just under the tip of the screw driver. I tried to get a pic with the screw driver tip on the piston but it obsecured the view so I just touched it to the retaining nut around the piston. What is this valve called? The control valve? Seems like I read in the manual that there is a control valve inside where it is protected.
   / Leaking hydraulic valve #4
Yes, that is the control valve. #15 is the seal on the control valve shaft. You can click on that number and it will bring it up for you.
Thanks winston! That is exactly what I couldn't find.
   / Leaking hydraulic valve #6
Is that not the valve that controls the descent rate or locks the 3pt.
It has several seals, and you should be able to re-seal
What is the purpose of the lever with the red tip?
JJ that is the valve that locks the 3pt. and the red tipped level controls the speed of descent. There is a knob under the seat that either locks or allows the lift to travel. I think I'll order a new seal for just a couple bucks and try that to fix it, then if that doesn't work I guess I have to buy the whole valve assembly.
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
12in Backhoe Bucket (A52128)
12in Backhoe...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2008 SATURN VUE (A50324)
2008 SATURN VUE...
