Leaking hydraulic top link
   / Leaking hydraulic top link #1
MacFacts
Killeen
2002 TC18
Can anyone tell me where I can get one of these or have one made? Tube got bent from broken implement and I
have tried to straighten it but it still leaks?
   / Leaking hydraulic top link #2
Is the leak on the actual tube or on one of the fittings?
Leaks from fitting at block. Around the tube.
   / Leaking hydraulic top link #4
Try tightening that hex nut on the a little bit more so it seats the ferrule inside better and see if it works.
I’ve tried that and it won’t budge anymore. I think a new ferrule might work, but can’t find that either.
   / Leaking hydraulic top link #6
Can you take all that metal stuff off and just put the hoses in each end like a normal cylinder?
That’s how my hydraulic top link is.
   / Leaking hydraulic top link #7
It's most likely metric tubing, the compression fittings on the valve are part of the valve cartridge so not really replaceable, I think there's an adaptor that will convert them to a common size but I haven't looked into it yet.
Sent from my SM-G715U1 using TractorByNet mobile app
   / Leaking hydraulic top link #8
   / Leaking hydraulic top link #9
They make adapters to go from banjo to NPT. You could take everything off the cylinder and attach the hoses directly. You could also take that cylinder to a hydraulic shop, they might have a way to replace just the steel tube that has the leaking fitting.
   / Leaking hydraulic top link #10
Just need to know where to look.
It seems like they are out of a lot of things at this moment, but they are a source for the parts.
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
6ft Field King 3 Point Hitch Tiller (A51573)
6ft Field King 3...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
