leaking hydraulic oil
   / leaking hydraulic oil #1
fixin40
Central New York
Massey Ferguson 2410
Hi all,
I have a massey ferguson 2410 and was digging a hole with the backhoe the other day. The temp out side was probably 34F and I let the tractor warm up for 15 minutes or so before I started to dig. I noticed the smell of hydraulic fluid early on but did not see anything. I repositioned and noticed hydro fluid on the ground underneath were the tractor had been. I immediately dismounted and looked under the tractor and did not notice anything leaking. The tractor still worked and I did not notice any further leaking so I completed the job(another 2 hours) and brought the machine home. My question is, when I started to work the backhoe did the cold hydro fluid in the backhoe some how cause a relief valve to lift on the transaxle and once the fluid was mixed and warm the relief no longer lifted? Just trying to figure out what happened. Any thoughts would be appreciated.
   / leaking hydraulic oil #2
Hi all,
This question would have been better over in the Massey specific forum:
Massey Ferguson Owning/Operating - TractorByNet.com
If you contact a moderator they can move it for ya.
I'm not aware of a relief valve on it, but, there may be one. Be sure to check your sight glass and make sure you are full on oil.
   / leaking hydraulic oil #3
I don't think any hydraulic system that is plumbed properly has a relief that spills out on the ground.
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
