Leaking hydraulic fluid from the mid-PTO
   / Leaking hydraulic fluid from the mid-PTO #1
Phil48
Eastern TownShip
CK20 HST
Hello there! Last year, my dealer installed a belly PTO to power a front snow blower. So far, great installation and performance, but I noticed a small hydraulic fluid leaking from that bottom PTO. The 4 bolts holding the assembly all have a dripping nose syndrome! I try to retightens, but those bolts were already really tight. Anybody had that problem? Gasket, seal?
Many thanks in advanced
Phil
   / Leaking hydraulic fluid from the mid-PTO #2
There is an O-ring seal between the OD of the PTO unit and the ID of the hole in the gear case. O-ring may have gotten pinched sliding it into the gear case. Another possibility: If the blot holes are drilled all the way through the gear case so the ends of the bolts are exposed to the fluid, the bolt threads should have some type of sealant on them to keep fluid from working around the threads.
Either way, you will need to drain all fluid to inspect/repair.
Many thanks for the info, I'll now check with warranty!
Phil
Sorry for the delay. Actually, my dealer could have done the job way sooner, but I couldn't free myself. It ended up as a faulty gasket, nothing serious and everything under warranty! A very well train mechanic came over, dismounted the mid PTO, thoroughly check everything, change the gasket and the O-ring. No more leak!
As I read way back on this web site: " Pick a tractor you like, but choose very wisely your dealer"! Ah! wisdoms! It's priceless!
Phil
SKIDPRO  SKID STEER GRAPPLE (A52472)
SKIDPRO SKID...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2015 PJ TRAILER  16 TANDEM AXLE UTILITY TRAILER (A52472)
2015 PJ TRAILER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2016 JOHN DEERE 8245R LOT NUMBER 182 (A53084)
2016 JOHN DEERE...
