Leaking hydraulic CT225 steering
   / Leaking hydraulic CT225 steering #1
autoenvirons
Bobcat CT225
The fitting suddenly started leaking and I soon lost steering just as I got into barn. The bolt seems tight - I understand there may be either copper crush washers or O-rings under the bolt. How difficult is this to disassemble and where do I source replacement parts?
I had noticed a very slight leak a few days ago, but it is suddenly spraying everywhere.
What trouble will I get into trying to do it myself?
   / Leaking hydraulic CT225 steering #2
That banjo fitting should have two O-rings inside. Should be a matter of pulling the bolt off, take the o-rings out and put new ones.
You can go to an hydraulic shop or auto parts store to match the size or just order a set online. Those are very cheap.
Thanks very much for the quick reply
Thanks everyone. I found the proper O-rings size and reinstalled. Then I realized there was a small (fatigue?) crack at the banjo joint. Tried to order a new hydraulic solid line but back-ordered at least 6 weeks. Finally found someone to TIG weld and reassembled. Had to add nearly 9 gallons of fluid, but runs perfectly now.
2004 Jeep Grand Cherokee SUV (A50324)
2004 Jeep Grand...
2010 Ford Expedition XLT 4WD SUV (A50324)
2010 Ford...
2014 Ram 5500 4x4 Altec 37G 37FT Bucket Truck (A50323)
2014 Ram 5500 4x4...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
6' AGT Skidloader Rotary Mower (A50774)
6' AGT Skidloader...
2023 Third Coast Equipment RA12H Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2023 Third Coast...
