JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,724
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
Moved more dirt from my top soil reserve pile up to my garden, Drug boxblade most of the time to smooth out my "road" down to my pile of dirt and back up to the garden. Finished my dirt moving/boxblading and ready to reinstall MMM since grass is about a foot tall.
Turned tires on MMM so they will roll under tractor and notice a wet spot. Check and fuel is dripping off the two lines held together with plastic ties right near fuel filter and silver thing that looks like a fuel filter. Dryed lines and felt up them both and located a rubbed spot on the line that is not going into the fuel filter. The rubber boot had slid back on I guess drive shaft and it must have spun with the drive shaft and rubbed thru hard ribbed plastic cover over line and then almost thru the side of the fuel line. Will stop by Barlows tomorrow for fix advise but maybe someone here has some sage wisdom as to best/easiest repair. In my mind I'm figureing some type of metal tube slid into the ends of the fuel ine after I cut it and then a clamp at each end. Yahs or nays?
