Leaking fuel filter on my Bolens G174
   / Leaking fuel filter on my Bolens G174 #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
Ever since I removed the float bowl to clean the filter, the thing has leaked a bit. Then it drained the tank and my neighbour ran it dry, so off it came again. I tightened it carefully with a channel lock wrench. No go. Last night I carefully assembled the thing and tightened it gently against the O ring. It leaked about a litre overnight.
Bleeding the fuel system after every attempt to fix it makes me reluctant to deal with this. It seems diesel leaks are a bit beyond my level of mechanical competence, but I wonder if there is a cracked part somewhere above the filter bowl.
How do I fix it?
   / Leaking fuel filter on my Bolens G174 #2
Be sure where the leak is originating ,so that hard to see parts are not cracked that cause it to leak .Try a new o-ring ,with some Vaseline petroleum jelly,or a little grease to allow for movement while getting proper seal.
   / Leaking fuel filter on my Bolens G174 #3
Do you have a plastic bowl or metal? Take it off and use your thumb nail and check the sealing surface for nicks or cracks. Like the other poster said always use vaseline or silcone grease so the O ring stays flat
2020 KUBOTA RTV...
CAT 973 (A47384)
CAT 973 (A47384)
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2001 Trail King TK18LP / TK20LP / TK40LP Paver Special Trailer, VIN # 1TKC027231B046890 (A51572)
2001 Trail King...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
