Leaking fittings
   / Leaking fittings #1
Bday
Lucerne, IN
53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
I replumbed some lines on a tractor for a loader. Used loctite ptfe paste for sealer. Tightened the crap out of them, and tightened the crap out of them again. They are still weeping. What next? I hate hydraulic fittings!
   / Leaking fittings #2
What style fittings you using? I usually use Teflon tape.
   / Leaking fittings #3
Teflon pipe paste works great.
   / Leaking fittings #4
I've actually had people that are "supposed" to know what they're talking about tell me not to put Teflon on hydro fittings. I never understood why. So guess what? I use it anyway!
   / Leaking fittings #5
Teflon tape will work if your very carefull, do not get any in your hydro system. This usualy happens when taking apart a fitting,that has had tape on it, small peices can get in the system and caught up in valves, you would not want to get caught using it on a manlift or bucket truck! Its best not to use on hydralics.
   / Leaking fittings
Not sure what type of fittings they are. I bought ready made hoses at the local farm store. Used 1/2" to 1/2" female couple to connect the lines. The lines had quick disconnects on them that are now connected to the couplers and then the new lines.
   / Leaking fittings #7
Are you using standard water/gas pipe coupler, these wont hold up well to hydralic pressure. The hydralic coupler will have six sided flats for a wrench, and is much thicker.
   / Leaking fittings #8
Are they straight thread or pipe thread? I've used Teflon tape for some time now. At work that's all we use at VanDorn Plastics
   / Leaking fittings
I believe they are pipe thread. I grabbed them from the hydraulic section next to the hoses. Had to get one from Napa because we were one shy of what we needed. The one from napa was the same fitting.
   / Leaking fittings #10
I am willing to bet if you look your fittings are not compatible.
UNUSED LANDHERO T-TOP & WARNING BURTINGS (A54757)
UNUSED LANDHERO...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
