Leaking FEL cylinder after sitting
   / Leaking FEL cylinder after sitting #1
wcpeabody
earth
JD 770
So this winter has been very mild and the 770 with 70 FEL has been sitting for most of the winter. Last weekend I moved a little bit of gravel and I noticed one of the cylinders is leaking pretty good when it is moving. Leaks to the point it is not dripping but has a small stream coming out. My plan is to take it off and take in to a local shop to have it rebuilt (any personal suggestions for a shop in Spokane). Last fall the cylinder was not leaking to the point it was dripping.
But the question I have is, it did not leak when it was put in the shop a few months ago. Did sitting make it go bad, coincidence?
Thanks in advance,
Bill
   / Leaking FEL cylinder after sitting #2
IMHO.........coincidence......I owned a 770 for a few years......it had about1250 hours and between the loader and the backhoe I had one leaking at all times. I was on a first name basis with the guy at the repair shop.:eek:
2011 FORD F-450 (A52472)
2011 FORD F-450...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
2018 FREIGHTLINER M2 106 26' REEFER BOX TRUCK (A54607)
2018 FREIGHTLINER...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
