Leaking differential fluid on Kubota?
   / Leaking differential fluid on Kubota? #1
Zockel
Kearney, mo
Kubota 3430
I noticed some fluid on the rim of the right front wheel of my L3430 yesterday. It had the consistency and smell of hydrolic fluid, but I know very little about this. I took the wheel off and it appears to be coming out of the crack behind the hub. What do I do next? :confused3: Thanks in advance for any help in diagnosing the problem.
I tried to post a picture, but the upload keeps failing. Will try again later.
Pete
   / Leaking differential fluid on Kubota? #2
On my L5740, and several others with Grand L 40's on this site, that has been the first sign your outer wheel bearing has failed. If you have a loader, raise the front wheels off the ground and see if you feel any free play in the wheel. Mine was getting very loose when I spotted the leak. Front bearing failed but no other damage. I replaced the seal and both bearings plus the housing seal ring for about $90 plus 1 hour of my time
Thanks, that doesn't sound too bad. Tried the picture again, but each time get the upload failed message. Tried jpg and gif and reduce to less than 100kb, no success. So the fluid appears to be leaking out from behind the plate to which the wheel attaches. Is there a diagram somewhere to tell me what parts I need to order, or is it best to take apart and drive to the Kubota dealer?
   / Leaking differential fluid on Kubota? #4
A parts diagram will show you what you need. Can get it online at your dealers website or Kubota's website.
2021 International HV507 12ft Dump Truck (A51692)
2021 International...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
Toro Workman GTX (A50121)
Toro Workman GTX...
2020 Freightliner M2 106 S/A Dump Truck (A50323)
2020 Freightliner...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
ATTENTION PLEASE READ (A50121)
ATTENTION PLEASE...
