Leaking Backhoe Valve- KB2475L
   / Leaking Backhoe Valve- KB2475L #1
Powderhorn
Canada
Kioti CK30
Good day folks,
I posted this in another section and didn’t get any response, hoping to get some here.
Leaking Backhoe Valve KB2475L
I think I may have found enough info now to have a better idea of what is the issue. The leak is coming out around the valve lever for the left stabilizer leg. I’m wondering if I take off the “lever pivot box” is the spool going to come shooting out?
Here are some more pics:
Leaking under the white plastic cup/cover when actuated.
   / Leaking Backhoe Valve- KB2475L #2
Like you I have never had this unit apart and I am just guessing but from the drawings it looks like the spring is a centering spring so that the spool returns to a neutral position.
I would guess that when you remove the the pivot box this spring does not have much if any compression on it.
as you’re removing the box un-tighten the fasteners in an alternating pattern to see if the pivot box becomes loose. If it does then the spring is not compressed.
Let us know what you find.
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
