leak
turkeyhunter
It seams I have a hydro leak. It's coming out around the shaft for the pto hook up. Is there a seal or gasket that needs to be changed or could it be something major ? The model is a ym 2200. I guess there is a seal or a rubber O ring there is it hard to change ? One more thing to. When I bought this ym 2200 the guy had two of them. The difference was that one only had one place for the hydro and that was at the gear shifter. The one I bought has two one in the same place and then one at the top of the rear end kinda under the seat. Is this just another extra place to ad fluid ? Whe I changed the trans fluid the drain was at the bottom of the pto at the rear. But it didnt drain it from this extra place that I talked about above any thoughts on what this might be and my leak ? Thanks as always for the help. Sorry so long. /forums/images/graemlins/shocked.gif
That is a common problem. PTO seals and axle seals dont like it when the tractors are shipped dry and then re-filled with oil. There is a seal in there. I believe, someone correct me if I'm wrong, there is a 4 bolt plate that comes off.The seal should be inside the plate. i dont remember it being a tough fix.
Hope this helps,
Aaron
parts@HoyeTractor.com
(940)438-0386
/ leak
Thanks for the help. /forums/images/graemlins/grin.gif
2021 Ford Explorer AWD SUV (A61574)
2021 Ford Explorer...
Container W/Side Window & Door (A62183)
Container W/Side...
Giyi Pile Hammer (A62183)
Giyi Pile Hammer...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2018 Unverferth 3955XL Seed Tender (A63116)
2018 Unverferth...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
