leak from split pin in hole below trans
   / leak from split pin in hole below trans #1
Maddog_Riverslea
Gday ... I have a 500 series massey...its leaking fom the split pin that sits lossely in the hole below the transmision housing ( more than just dripping )..(multipower tractor ).whats the most likely reason ? will it be expensive .please tell me the best and the worst ..Doug (Maddog)
   / leak from split pin in hole below trans #2
First question..... Is it tranny oil? Or is it engine oil?
I'm not all that familiar with 500 series, but on the Massey's I am familiar with, here's the choices. Tranny oil; Multipower has a seal between the tranny and the bellhousing. It can leak. Also the front input shaft seal can go, but not that common. Engine oil; Rear main seal. Older Perkins had a tendency for the rear oil pan gaskets to leak, ending up with oil in the bellhousing.
That weep hole you're referring to is there to deal with any leaks into the clutch area. A few drops every now and then won't hurt anything. It just drips out that weep hole. A BIG leak can take its tole. Oil down your clutch real good and you get to spend some MORE money.
Oil pan gaskets are relatively cheap and can be changed by anyone handy with the wrenches. Rear main seal means splitting the tractor. Either tranny seal will require a split too.
Better tune up the wallet, 'cause you're getting ready to put it to the test. :(
Swict 72" Bucket (A50121)
Swict 72" Bucket...
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2012 Chevrolet Traverse LTZ SUV (A50324)
2012 Chevrolet...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
