Leak at sight glass
/ Leak at sight glass #1
longnkrnch
Kubota L3010
My L3010 has a sight glass to keep tabs on the hydraulic fluid level. It seems that the fluid is leaking from around the sight glass and accumulates all around the PTO and hitch. Does anyone know if it is easy to remove and reseal this sight glass?
/ Leak at sight glass #2
post a pic
soundguy
/ Leak at sight glass #3
That is a good question for a (Kubota?) dealer.
As Soundguy writes, a pic would be nice.
While you're getting that picture, can you see any kind of nut or plate around the sight glass? Something removable?
I'm going to guess the sight glass is affixed on the inside of the case though and it's probably just an o-ring seal leaking.
/ Leak at sight glass #4
New site glass is less than $10. Drain the fluid down past the glass (or park it downhill), pop out the old one, clean the area and put the new one in with some hi-temp RTV. It is just an o-ring seal but the new site glass will have one on it already.
Mine cracked on a L3600.
/ Leak at sight glass #5
i figured it was just an oring seal issue.
soundguy
/ Leak at sight glass #6
If it's like the L2800 it screws out and back in. It has a flat rubber washer to seal it. Mine started leaking and didn't realize I could have tightened it up and probably not lost it because it came out.
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
IRMC High-End Massage Chair (A64047)
IRMC High-End...
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
