leaf vaccum help
   / leaf vaccum help #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
my dad is giving me his older ez vac leaf vaccum, when he gets a new one, its the model that has 4 steel sides that slide together to make a square to fit in a lawn cart and it has a 5hp motor that has a mount to go on the hitch of the tractor, that allows the cart to be taken off seperate. my main ? is does the ez vac manufactorer still exsist? as this machine is about 25yrs old. it needs some hoses which i can easily get,the motor is basically new it only has about 3 seasons on it. it def needs a new cover that goes over the collection hopper, and also i would like to get a new chute for it that goes to the mower deck as the one we have for it now has seen better days after 25 yrs of use. i was looking for the chute assembly on line but can't seem to find one, i think trac vac makes them for most mowers and i could probably get one from them that would work. any info would be great thanks jim
   / leaf vaccum help #2
Just about every leaf vacuum manufacture makes a good supply of chutes for their vacuum systems. Just contact them and tell them you want a chute for XYZ model, whatever. They might sell you generic chute that you can modify to fit. One of my chutes is plastic, and one is metal.
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
Kubota BX2230D (A47384)
Kubota BX2230D...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
