Leaf Vac selections
/ Leaf Vac selections #1
MrJoe
Southbury, Conn.
Case IH DX24E
Good Day to all: just got my CaseIH DX24E and want a leaf vac. Anyone out there with recommendations? /forums/images/graemlins/confused.gifI want the tow behind, non PTO powered type. Hava about two acres, big maples and oaks to clean up after, small tight yard. Thanks for any opines. Joe
/ Leaf Vac selections #2
I saw one today at TSC for $999.00.. others TBN'rs have made their own.. I'd like to know where the blower section could be purchased.
/ Leaf Vac selections #3
DR (Country Home Products) just added pull behind lawn vacs to their line. Their stuff is pricey but usually well made and they do stand behind it. They have added a lot of products to their line that they obviously do not manufacture but nothing wrong with that. Sorry, but I don't have the link handy.
Vernon
/ Leaf Vac selections #4
Look at the Cyclone Rake.... Just don't go for the smaller of the units. Made that mistake on their recommondation. Just wish it would hold more... hence the larger unit. Plastic impeller is great. Picked up rocks, branches, etc. and never failed. They are greatly improved since I purchased... but overall, I am satisfied with the unit.....
/ Leaf Vac selections #7
MrJoe,
I investigated options to build one as I had a cart, and was going to purchase a used vac unit. However adding up the costs $600 for the vac, modifications needed to the cart etc, and leaves were falling I purchased the Trac Vac 580 Model with 5.5 HP B&S 2 yrs ago $1600 to pull behind my 18 HP Cub Cadet. w/44" deck
Pros of the Trac Vac - Large capacity cart with metal construction, packs materials tightly in from front to back based on the design, fast and easy unload, sucks materials from wet grass and leaves to small sticks, and large tires dont mar lawn.
Cons, overall size 7' long with hitch takes some storage space, also you need to watch pulling around obstacles like walls, borders, trees etc.
We have oaks, with acorns and pine trees, and landscaping to manuever around and it has done a great job so far. I only use it in the fall leaf and spring cleanup after thaching the yard. I also do clean up for a small fee at three other neighbors yards giving a small ROI.
Every fall we end up with a large pile of mulched leaves and grass 15x30' x6' high that I spread some fertilizer on and by mid summer 10-12 yards of great compost to use.
I got the wand attachment that has never been used as it is much faster to simply blow the leaves from the beds then vac off the lawn. I looked at the Cyclone Rake as an alternative, and they were $1300 range, howver soft sides could clog over time, are not as easy to unload, but are lighter, and easily stored.
The only problems I have had are sticks getting stuck in the input chute which I think would be an issue with any vac, then acorns dented the output pipe (galv flex steel) from the impeller, and the fasteners holding the bin together loosened after the first 10 hrs, but are fine since tightening.
Having any lawn vac in my opinion beats raking so good luck in your mission.
Carl
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
karcher pressure washer (A61567)
karcher pressure...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
