LCD Television
   / LCD Television #11
Bird,
Last year I bought one of the magnavox's from walmart. I put it in the horse trailer and it has held up just fine. I would think that would be a pretty big test for one to go flying up and down the road getting bounced around alot. The one I got was a 20" and it was $299.
   / LCD Television #12
Bird - I have never owned an LCD monitor, but seeing them in the stores they seem to have good picture quality. UNLESS you get off to the side. Then the picture quality seems to fall off rapidly. A very narrow viewing angle. Check that out next time you look at one and think about how you will be viewing it in your home. We ended up buying a DLP for that reason, but we did not need to hang it on the wall or mantle either. The plasma was way more than I wanted to pay.
   / LCD Television #13
LCD vs Plasma vs DLP ... vs what's next? /forums/images/graemlins/confused.gif I don't have to make a decision for a few more years yet ... but I'm hoping the old BETA vs VHS thing will sort itself out by then. A guy I work with just bought a 42" DLP - the one failing in it is the light bulb ... guess it burns out in about 4 years. ? Course by the time beta vs vhs starts to sort out - they'll come out with dvd............. /forums/images/graemlins/crazy.gif
   / LCD Television
I've heard of DLP, but don't know what that is. /forums/images/graemlins/confused.gif I guess I could go buy one and that should make'em obsolete real quick. /forums/images/graemlins/crazy.gif
   / LCD Television #15
DLP is digital light processing and has really been hyped lately. Ours does have a great picture. I don't know exactly how it works, but it does have a very bright lamp in the back. That lamp is fan cooled and the fan continues to run for a few minutes after you turn the TV off. It is almost essential that you have a small UPS (uninterruptable power supply) in case your power goes off while you are watching TV. Losing power to the TV while the lamp is hot will greatly shorten the lamp life. We have had ours for several years. We had a power outage shortly after we got it and the lamp burned out a few days later. But they replaced it under warranty. Now if we have a power outage, we turn off the TV and let the UPS keep the fan running until it cools and no further problems.
The really odd thing about it is that it looks basically like a CRT type TV though not quite as deep. But even at 42" screen, I can easily pick it up by myself and move it around. And my back ain't what it used to be. /forums/images/graemlins/crazy.gif
   / LCD Television #16
The Consumer Reports article has a short explanation of each technology, their Pros and Cons, e.g., LCDs and viewing angle, Plasma and weight and heat, etc. as well as the approximate price range.
   / LCD Television
I haven't looked at a Consumer Reports magazine in a long time; guess I need to pick one up, but I'm thinking more all the time that the best thing to do is just keep using what we've got. /forums/images/graemlins/laugh.gif
   / LCD Television #18
We have a DLP as well and I love it. A DLP definitely will not mount on the wall though (at least not aware of any) as they are pretty thick, but light. My wife and I carried our 52" DLP upstairs, which includes a 90 degree turn in the stairs, and set it in place our selves.
The DLP uses a single cannon/light source and works by "flipping" thousands of tiny mirrors on a semiconductor chip. Color is generated by shining a light through a rotating color wheel that has red, green, and blue (or individual color wheels) on it. The colored beam hits the semiconductor chip to create the image used for projection. There is a fan that keeps the bulb cool, but sometimes the sound that is mistaken for the fan blowing is actually the color wheel turning. Seems like I read once where the color wheel(s) can turn at up to 10K RPMs. Unless you are up close, which you do not want to be due to pixelization on a big screen, you can’t hear this – at least not on our Sumsung.
If wanting to mount on a wall, the LCD or plasma is the way to go. The plasmas are expensive but you can get two or three years out of them before noticing picture degradation. The LCDs are coming down in price and you can get up to 5 years out of them before the picture starts to degrade. The plasmas can go up to about a 60” (I think) but the LCDs go up only to 40”. I have read though that not all plasmas can faithfully reproduce the HDTV signal. Want to check and make sure of the resolution if interested in HDTV. Both the LCD and Plasma have “poor black level presentation”, meaning that black and very dark colors are not rendered clearly which can affect overall picture quality. Both can suffer from burn-in if a picture or background is paused or left projected for a long time (pausing a DVD, video games, etc.).
Once again, we really like our DLP. If you do not have to hang from a wall and have the room I feel like the DLP is the way to go – even if the DLP and plasma were the same price. I am to understand the DLP bulbs will last three to five years then it costs about $400 to $600 to replace. The semi-conductors last for up to 25 years. The picture quality is excellent – especially for HDTV and DVDs. Regular broadcast channels and you can see, it’s not terribly noticeable as my wife never sees it, some of the “green effect” that DLPs are known for - inability to render various green shades clearly. DLPs are also known for "rainbow effect" where if you focus on a particular area you will see red & blue haloes around other parts of the screen due to the "strobing" of the color wheel. This use to be real issue when the DLPs first came out, but, I believe as the semi-conductors have gotten better this has greatly diminished. The best way to check is just go to a store, get normal distance away and stare at a particular spot on the screen. Let your eyes go out of focus and see if you notice this effect. When we bought ours a couple of years ago it was hard for me to find DLPs that would do this to where it was really noticeable.
One thing I will pass on though. When I bought our DLP it had I think 12 inputs: (3) each composite (RCA type jacks) and S-video, (2) BNC/Antenna, (3) Component (R/G/B) and (1) PCI/DMI for computer. When I got it I thought, this is overkill – will never need since majority of connections will go to my surround sound receiver. But, after a few years I am using almost all of them, so get as many as you can.
TV’s are like tractors. Figure out what you need and want in one, check out a few and then get what best suits your needs and what you will be happy with. What works for me may not work for the next guy, so, I will only pass on what I have learned – and help you spend a little money /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
-Eddie
   / LCD Television #19
Things to know
First, check with the manufacturer: many times the specs on TV as showm in electronics stores are deceptive. For example a TV may be called HD which is not, in fact, HD, but which can accept (but not display) HD signals.
Second, understand that flat panel display technologies are more or less, irreparable. That means that pretty much, these things are replace on failure.
Finally, 'flat panel' televisions are rarely actually wall mounted on account of the challenges with cablling. A modern TV requires a pile of cables and such to work. Plus, you have to mount DVD players, and so forth, farely close to the TV because there are all kinds of limits on how far a signal can be piped over a cable.
Oh yeah, and a lot of folk tell you don't mount over a fireplace, but I am not sure how valid that commentary is.
   / LCD Television #20
I agree. I know my LCD Epson bulbs goes by hours not years. Most are like 2500 hours to 3000 hours max; then $300 +/- for a new bulb.
That is a lot of views of Blazzing Saddles, History of the World, etc. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
So far, I would not buy another TV unless it is smaller them a shoe box!
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
