Lb2204 not charging
/ Lb2204 not charging #1
Banjobend
Redmond
Lb2204
Hi there,
I have an lb2204 that hasn't been charging. Idiot light had been illuminated for a while, off and on. Final the battery died so I had the alternator tested and its good. I've gone through the wiring and it all seems good. No corrosion on any connectors either. I'm wondering if a bad voltage regulator could cause a no charge.
Any help?
/ Lb2204 not charging #2
yes a bad regulator could cause this and is probably the only other device in the charging circuit.
Ok. The only one I found is $62, didn't want to buy that without really knowing if that could be the problem.
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
Great Plains 7326DH (A64126)
Great Plains...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
Cattle Feeder (A65640)
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
