LB1914 Wont Charge. Regulator? Alternator? Multimeter Question...
   / LB1914 Wont Charge. Regulator? Alternator? Multimeter Question... #1
shaw1ak
lowell
Kioti LB1914
Hello Everyone,
This is my first post so thank you in advance for any insight.
I just put in a new battery, however, my "lighting bolt" / "charge" light is on while running. Yesterday after mowing for 2 hours, it wouldn't start once shut off. I checked my battery and it read ~12.4 volts. I checked the battery again while running @ 2000 RPM, after i put it on the charger on, and it read ~14.5 volts. Is this in the expected range? How can I trouble shoot my Regulator and Alternator with my Multimeter? My shop manual is missing the charging system diagram, conveniently:confused: Any advice on how to trouble shoot these two components, or other advice is greatly appreciated!
Thank you,
Ashton
   / LB1914 Wont Charge. Regulator? Alternator? Multimeter Question... #2
That sounds about right. When you checked it when it would not start did you check the battery voltage when you tried to start it to see if voltage dropped ? The light is on when you tested it at 14.5 volts??
   / LB1914 Wont Charge. Regulator? Alternator? Multimeter Question... #3
I agree, those are good numbers. 14.5 V is a good regulated output.
The process I use with a Voltmeter.
Across the battery terminals with everything off. (12.5 or so)
Across the battery terminals with key on, and some load like the head lamps. (ding a volt )
Across the battery while operating the self starter (> 9V, more is better ;-)
Across the battery with the alternator spinning just over a "fast idle" (14.5V)
Then I like to measure from the battery + POST to a good ground, followed by the + CABLE clamp to the same good ground. (should be EXACTLY the same)
Look for bad connections between the battery and the starter, don't neglect the solenoid.
UNUSED 1RANCH 1RETC HYD THUMB CLAMP (A57193)
UNUSED 1RANCH...
(4) BF GOODRICH MUD TERRAIN TIRES (A57192)
(4) BF GOODRICH...
2008 Ford Ranger Pickup Truck (A55852)
2008 Ford Ranger...
1999 JOHN DEERE 260 SKID STEER (A52707)
1999 JOHN DEERE...
2017 Bobcat S650 High Flow Compact Wheel Loader Skid Steer (A55851)
2017 Bobcat S650...
John Deere 550L Crawler Tractor Dozer (A55851)
John Deere 550L...
