LB1914 Steering ?
/ LB1914 Steering ? #1
AltaLawnCare
Gladys, VA
My 1914 steering seems to slip.....
When turning slow, its fine, but if I spin it the wheels don't seem to want to turn,...is this normal. A buddy adjusted the front wheels, which were out...so tcould have hit something earlier in its life.
Anyone run into this before?
/ LB1914 Steering ? #2
I'm not sure I can help with this one !
It could be a number of things-restrickted oil line,bypass valve needing adjusted,control valve not deverting the oil properly.
/ LB1914 Steering ? #3
Just out of curiousity I spun the steering wheel on my DK today.
And the wheels turn as fast as I can spin the steering,so you have a problem some where..
/ LB1914 Steering ? #4
My LB1914 is 10 days old but during the 6 hours I have spent on it, I have not been able to duplicate AltaLawnCare's steering problem either.
/ LB1914 Steering ?
Thanks everyone!
I guess the ole Kiotit will haev to take a trip to the shop...over winter when things slow down.
/ LB1914 Steering ? #6
This was happening to my power steering (not a Kioti). I didn't know what to do and didn't want to take it to a shop so I just changed the fluid. Lo and behold it works like new now.
Eugene
/ LB1914 Steering ? #7
Has anyone had a kioti LB 1914 steering shaft hollow out the directional valve coupler? At this time they are telling me I need to buy a new $900.00 dollar contoler.
/ LB1914 Steering ? #8
I have the Kioti LB1914 I have a problem with my steering, every now and then when I turn left I have to turn the steering wheel 4 or 5 complete turns before it catches and the wheels turn but if I turn the steering wheel to the right and then left it works fine. Not all the time, it's one of those clitches I've learned to work around. Other then that the tractors has been great :)
/ LB1914 Steering ? #9
I have the same problem as casey lb1914. It is a nuisance but I have learned to live with it.
It doesn't happen all of the time.
/ LB1914 Steering ? #10
If anybody comes up with a answer on how to fix this problem, can you post it.
Thanks Jim
2001 Mack CH613 Water Truck, VIN # 1M1AA18Y21W144276 (A65563)
2001 Mack CH613...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
Continental Cargo 24' Enclosed Trailer (A66285)
Continental Cargo...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
MAGNUM LIGHT TOWER (A65643)
MAGNUM LIGHT TOWER...
