LB1914 Kioti charging idiot light
   / LB1914 Kioti charging idiot light #1
Kioti Kid
My battery has been running down and I checked the generator which was bad and installed a new one. The voltage now registers 13.6 volts so it's working, but the dash idiot light for charging won't go off when the tractor is running. What might cause this to happen?
   / LB1914 Kioti charging idiot light #2
Voltage regulator has been known to cause this symptom.
I used one for a 1970 Toyota pickup on my lk2554 and it has been working perfectly. The plug and wiring was the same. It should be the same as yours as well.
   / LB1914 Kioti charging idiot light #3
You may have a loose or dirty battery connection. Check the battery voltage when the tractor is not running then check it again when the tractor is running. Turn on some lights and see if it varies.
   / LB1914 Kioti charging idiot light #4
While we're at it, I believe a Mazda B2000 alternator bolts right in after swapping pulleys with the OEM.
   / LB1914 Kioti charging idiot light #5
Yep did that too although I did not change the pulley just got a shorter belt.
Thanks I suspected it might be the voltage regulator.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
