lb1914 hydraulics .
/ lb1914 hydraulics . #1
pastormikey
erwin, nc
kioti lb1914
i have just purchased a used lb1914 with a 1210 fel with 500 hrs. i had it serviced at a local dealer had all fluids and filters changed. my question is should this bucket have enough lift to lift front end of tractor off the ground. the hydraulics all seem to work fine but does not seem to have a lot of down force pressure. is this because it's only 19hp. i have checked the diverter. thanks for any help.
/ lb1914 hydraulics . #2
My tractor will lift the front end no problem as long as I have the RPM's above 1800! For how stout these machines are, I always wondered if anyone has put a larger Hydraulic pump on one to boost FLOW, if so maybe they can share their experience.
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
UNUSED JCT 2 PRONG BALE SPEAR (A65055)
UNUSED JCT 2 PRONG...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2026 Loadtrail 20ft. 7 Ton T/A Deck Over Flatbed Equipment Trailer (A64194)
2026 Loadtrail...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
